Expect noticeably less range as November temperatures drop, often in the range of 10 to 30 percent depending on the car and trip. That’s real, but it’s not the collapse some headlines suggest.
- Track your own winter efficiency for a few weeks.
- Plan trips with extra margin while you learn your car.
- Short trips in the cold use more energy per mile than long ones.
- A heat pump, if your car has one, reduces the loss.
Great EV reminder! Cold weather can affect battery range, but understanding your vehicle’s winter efficiency makes trip planning much easier. Tracking your energy use and allowing extra range for shorter trips can help avoid charging surprises along the way.
Cold weather definitely changes the EV driving experience, but understanding your own car’s winter efficiency makes planning much easier. Tracking energy use and leaving extra range gives you more confidence and fewer charging worries!
