Dry Your Gear Before It Rides Home
Wet tents, packs and rain shells shut inside a vehicle bring mildew, odor and fogged glass. A little drying time at the trailhead saves a lot of cleanup.
  • Shake out and air-dry gear while you pack up.
  • Keep a separate bag for anything still damp.
  • Run the AC or defrost on the drive to pull moisture out of the cabin.
  • Fully dry and unpack everything within a day of getting home.
3
Recommendation ↳ Trail steward's note
If your windows fog every time the wet gear comes home, a reusable moisture bag on the dash or under a seat helps a lot. Recharge it and use it again.
Reusable Car Dehumidifier Bag
Shop it on AutoMaximizer.com →
Great camping tip! Wet gear can quickly lead to musty smells, mildew, and moisture inside the vehicle. Taking a few minutes to air things out and separating damp items makes cleanup much easier and keeps your vehicle fresh for the next adventure!
Great tip! Damp gear can quickly lead to musty smells and moisture inside the vehicle. Taking a few minutes to air things out and keeping wet items separate makes cleanup easier and keeps the cabin fresh for the next adventure!
