Puffy coats compress in a crash and leave the harness too loose to work. Take the coat off, buckle up snug, then put the coat on backward over the straps.
- Do the pinch test at the collarbone. If you can pinch webbing, tighten it.
- Use thin fleece layers under the harness instead of a bulky coat.
- Tuck a blanket over the buckled harness, never under it.
- Check your car seat manual for its guidance on clothing.
3
Child passenger safety is so important, especially in colder weather! A snug harness and following the car seat manufacturer’s guidance can help keep little passengers protected on every trip.
This is such an important safety reminder! A bulky coat can interfere with a car seat harness, so always buckle your child snugly in thin layers and use a blanket over the harness for warmth. Always follow the car seat manual!
