Inspect wiper arms not just blades
Reality: the ten-minute cleanup has other ideas. A small maintenance habit can prevent misdiagnosis, protect finishes, and keep daily features working as intended.
A little patience, a quick check to start with the least aggressive inspection or cleaning method, and a willingness to laugh at the timing usually restore order. The story gets better once the problem is behind you.
