Match Your Hitch Class To The Load
Hitch receivers are rated in classes for a reason. Using a hitch rated below your trailer’s weight is one of the most common and most avoidable towing mistakes.
- Confirm your hitch receiver’s class matches or exceeds your trailer’s GVWR.
- Use the correct ball size — mismatched balls can pop loose under load.
- Torque the ball mount and hitch pin properly, then double-check before every trip.
