Record every change after the first drive
Reality: the late-night test fit has other ideas. A clean build is strongest when the visual decision also respects fitment, serviceability, and real-world use.
A little patience, a quick check to mock up the change before final finishing, and a willingness to laugh at the timing usually restore order. The story gets better once the problem is behind you.
Kids always seem to need a drink right when you get on the road! Keeping their water bottles within reach is such a simple trick to make family trips easier and cut down on unnecessary stops.
