Test The Battery Before The First Cold Morning
A battery loses cranking power as temperatures drop, and a weak one usually fails on the first chilly start. A quick test now tells you whether it will make it through the season.
  • Most auto parts stores will test a battery for free.
  • Look for corrosion on the terminals and clean it off.
  • Note the date code on the battery; most last three to five years.
  • Replace it before it strands you, not after.
Recommendation ↳ Recommended tool
If you'd rather check it yourself than drive to the parts store, a handheld tester like this reads cranking amps and battery health in under a minute. Clamp it on, pick your battery type, and it tells you whether it's good, weak or due.
12V/24V Digital Battery Tester
Shop it on AutoMaximizer.com →
Great reminder! A weak battery can catch you off guard, especially in colder weather. Having it tested and checking for corrosion ahead of time can save you from an unexpected breakdown. Better safe than stranded!
