The scenic roads are always the empty ones, and the station you counted on closed for the season. Fill up before the pretty part starts.
- Top off whenever you drop below half a tank on remote routes.
- Check station hours, since rural stops often close early.
- Note the distance between towns on your map ahead of time.
- Fuel is cheaper in town than it is after you run low.
