Watch fluid levels between sessions
Weekend challenge: make ‘watch fluid levels between sessions’ the one small thing you improve before the next outing.
  • Begin with a measured baseline
  • Change only one meaningful variable at a time
  • Inspect the result before the next session
No grand rebuild required. One cleaner habit is a win.
Definitely worth making this a habit! Checking fluid levels between sessions can help catch small issues before they turn into bigger problems. A quick check now can save a lot of trouble later!
