Check Ladder Racks At Eye Level
Loose bolts on a ladder rack are easy to miss from the ground. Check them up close before the ladder goes on.
  • Check the bolts and clamps on the rack weekly.
  • Look for cracks in the welds and brackets.
  • Make sure the ladder locks or straps work.
  • Tighten anything loose before you load.
Great maintenance reminder! Ladder racks carry valuable equipment, so checking bolts, clamps, welds, and securing straps regularly is essential. Before your next trip, take a few minutes to inspect every connection and tighten anything loose. Don’t load the ladder until everything is secure!
A quick inspection of your ladder rack can prevent serious problems on the road. Checking bolts, clamps, and straps regularly helps keep everything secure and protects both your equipment and other drivers. Safety first!
