Give door drains a clear exit
Every driveway DIY crowd has two personalities: the person who plans for this before leaving and the person who says, “We will figure it out.” Water needs a path out before it becomes an odor or corrosion problem. Which one are you?
A little planning goes a long way. Giving water a proper path out can prevent bigger problems later. I’m definitely on the “plan ahead” side! :automobile::wrench:
I’m trying to be more of a planner these days! A quick drainage check now can save you from a nasty problem later. Definitely worth the two minutes!
