Inspect wheel wells for contact marks
This-or-that for the community: do you begin with a measured baseline, or change only one meaningful variable at a time? Both camps have strong opinions, and both swear their way is faster. Which camp are you in?
I’m team measured baseline! Knowing where you’re starting makes it easier to track results and understand what actually works. From there, changing one variable at a time helps you make smarter adjustments!
I’m team measured baseline first! Having a clear starting point makes it easier to track what works and avoid guessing. Then change one thing at a time so you know exactly what made the difference!
