Keep Tongue Weight Between 10 And 15 Percent
Small changes in how you load can swing tongue weight a lot. Check it again any time the cargo changes.
  • Aim for 10 to 15 percent of total trailer weight on the tongue.
  • Weigh with a tongue scale or a certified scale.
  • Re-check after adding or moving cargo.
  • Too light causes sway. Too heavy overloads the rear axle.
Great towing tip! Even a small change in cargo placement can affect trailer stability. Always recheck tongue weight after moving or adding items. A properly balanced load makes a safer trip!
Great reminder! Proper tongue weight is essential for stable and safe towing. Even a small change in cargo placement can make a big difference, so rechecking the weight before every trip is a habit worth keeping!
