Torque and control beat speed on almost every obstacle. Momentum is the last tool, not the first.
- Shift into low range before the obstacle, on flat ground.
- Crawl up. Crawl down. Let engine braking do the work.
- Lockers if you have them, before you need them.
- If you need speed, use as little as it takes.
