Rated points only
Tie-downs and tow hooks are not the same thing as recovery points. Hardware fails in the direction nobody planned for.
  • Find your rated points at home, in daylight, with the manual.
  • Soft shackles and rated bow shackles. No ball hitches in the line.
  • Pull straight whenever you can. Side loads break things.
  • Lay a damper or a jacket over the line before anyone pulls.
Recommendation ↳ FOLLOW-UP
Somebody always asks what to use instead of a hitch ball. Soft shackle. Light, strong, and it doesn't turn into a missile if something lets go. Keep two in the bag.
41,000 lb Synthetic Soft Shackle
Shop it on AutoMaximizer.com →
