Store Water So It Cannot Roll
Loose jugs leak, shift under braking and can strike someone in a hard stop. Secure containers stay put and stay sealed.
  • Use jerry cans or jugs with tight caps.
  • Strap them to cargo anchors or set them in a fitted bin.
  • Keep them upright and low in the cargo area.
  • Bring more than you think you’ll need.
3
Recommendation ↳ Trail steward's note
If you're replacing loose jugs, a single 25-liter container with a tight cap is easier to strap down. Keep it upright and low.
25L Portable Water Storage Container
Shop it on AutoMaximizer.com →
Properly securing fuel containers is just as important as bringing enough fuel. Keeping them upright, sealed, and firmly strapped down helps prevent leaks and dangerous movement during sudden stops. Better safe than sorry!
Great cargo safety reminder! Loose containers can quickly become dangerous during sudden braking or sharp turns. Keeping fuel jugs sealed, upright, and properly secured helps prevent spills and shifting cargo. Always make sure everything is safely fastened before hitting the road!
