Understand Brake Fade On Long Descents
Brake fade happens when repeated hard stops build up more heat than the system can dissipate, reducing stopping power right when you need it most. Long mountain descents and track sessions both carry this risk.
  • Use engine braking on long descents to reduce brake reliance.
  • Upgraded pads and fluid raise the threshold before fade sets in.
  • If pedal feel goes soft or long, cool down before continuing hard driving.
That’s a great reminder! Engine braking really helps on those long descents. Definitely better to take it easy and let the brakes cool down than push them too hard. :+1:
